ASRock
4Core1333-eSATA2 Intel P31 Mainboard Review Intro 2/4
Gallery
At the bottom left corner you will see the 4 SATA II connectors controlled by the ICH7R south bridge. Just above it are external connectors for USB brackets. On the right are 4 DDR2 DIMM slots supporrting up to 4 pc of DDRII800 Total memory supported : 4 GB On the back panel, you will find the PS/2 Keyboard and Mouse, LPT1 port, COM 1, eSATA 4 USB, 1 1394, 1 GbE and 7.1 ch audio ports. eSATA is supported by cabling up the yellow connector on the South bridge with the connector right behind the parallel port.
