| CPU Configuration
page which shows the options available for adjustments. There is the CPU,
PCIe, voltage, multiplier, Flexibility option etc. |
System can be set to operate in ASync operation so that
PCIe bus is FIXED at a certain frequency. CPU Freq can be set from
200-400MHz while PCIe can be set from 100MHz-200MHz. |
