ASUS P5K3
Deluxe (Intel P35) mainboard review -
Features wise, this board uses the Intel P35/ICH9R
chipset. It supports the newer 1333FSB processors including all mutli core
processors. It has all the bells and whistles of any high end ASUS board out
there. The most important difference between the ASUS P5K3 is the removal of
PS/2 mouse port in replacement of 2 USB ports. This can be a bit inconvenient
for users who do not use a USB mouse or have misplaced their converter. On top
of that, the WiFi Access point is good but it could be an accessory addon rather
than bundled. The board also comes innovative features like AI GEAR 2 to save
power and AI slot detector (with diagnostics leds to check PCI/PCIe card
installation).
In our test, we are able to boost the memory up to DDR3-1510 at CAS 10-10-10-24. The CPU is run at 472MHz x 7 with a memory multiplier of 5:8. In a seperate test, we were able to overclock the E6300 to 500x7 Air cooled. For a list of options in the BIOS, you can refer to our Gallery for a view of the options available. Overall, this board has performed well for its first official BIOS. Using DDR3 is exciting but did not show major improvements in bechmarks. For its package and pricing, I would go for the P5K with DDR2-1066 until we see lower latency/higher bandwidth DDR3 modules appearing in the market.
Related Reviews 1
