DRAM Frequency allows you to run the RAM at
ASYNC ratio to the CPU CLK. On this board, when FSB is set to 266MHz, the
DRAM freq will just show up to DDR3-1066. FSB can be set from 200 ~ 800MHz.
The higher you go, the more async ratio appears for your selection. In fact,
DDR3-1333 is the somewhat the preferred choice when a 1333FSB CPU (to be
available) is used. |
