ASUS P5K
Deluxe (Intel P35) mainboard review -
of |
The most important difference between the ASUS P5K3
is the removal of PS/2 mouse port in replacement of 2 USB ports. This can be a
bit inconvenient for users who do not use a USB mouse or have misplaced their
converter. On top of that, the WiFi Access point is good but it could be an
accessory addon rather than bundled. The board also comes innovative features
like AI GEAR 2 to save power and AI slot detector (with diagnostics leds to
check PCI/PCIe card installation).
The overclocking features is very complete. With crazy voltage range, one can
test out watercooling for those high voltages. The FSB can even be chosen from a
range of 200 all the way to 800MHz. This is a bit too dynamic which most users
might not even use anything beyond 600MHz FSB.
In our test,we managed to overclock E6300 to 500x7 Air cooled. Although the board can POST up to 520 x7, it is not too stable at that level. For a list of options in the BIOS, you can refer to our Gallery for a view of the options available.
Overall, this board has performed well for its first official BIOS. With DDR2 modules pricing dropping further, this board would be a better choice. DDR3 would still be costly at this moment and availability is probably June. ASUS P5K with DDR2-1066 is definitely the better buy with a better price/performance ratio compared to its brother the DDR3 P5K3 Deluxe.
Pricing from |
Future CPU support
Plenty of oc options in BIOS
WIFi, AP
1394
AI Slot Detector
AI Gear2
No PS/2 Mouse port
Category |
Score |
Performance |
10 / 10 |
Features |
10 / 10 |
Ease Of Installation |
10 / 10 |
Overclocking Features |
10 / 10 |
Documentation |
9 / 10 |
Packaging |
8 / 10 |
| Cost/Performance Ratio |
9 / 10 |
Overall Rating : |
9.4 / 10 |
Related Reviews 1
Related Reviews 2
