ASUS P5K Deluxe (Intel P35)
mainboard review
- BIOS Screen Shots
of |
BIOS 1
DRAM Frequency allows you to run the RAM at ASYNC ratio to the CPU CLK. On this board, when FSB is set to 266MHz, the DRAM freq will just show up to DDR3-1066. FSB can be set from 200 ~ 800MHz. The higher you go, the more async ratio appears for your selection. |
DRAM Time adjustments |
CPU Voltage can be set up to 1.70v |
CPU Voltage reference option |
DRAM Voltage adjustments |
