ECS AMD690GM-M2 Integrated graphics mainboard (AMD 690G) Review - System CLK/Sandra XI
Bluetooth 27 Feb 2007
Benchmarks
In this test, we measured the CLK used by the boards. Both boards are set to run in SPD mode of the modules which is rated CAS 5, 5-5-15, 2T. The ECS RS485-M-M and SIS 771 reference board runs on 200.00MHz on the dot. The EPoX EP-AT690 Pro runs at 200.7MHz while the ECS AMD 690GM-M2 runs at default 200.00 on the dot.
With that in mind, we take a look at the memory benchmark scores using Sandra XI. 128M of shared memory is in use. We can see that the EPoX EP-AT690 Pro scores quite similarly to the older ATi RS485M-M board. The NVIDIA series boards seems to have an edge over the rest in this test. The SiS 771 graphics core seems to eat a lot more into the memory bandwidth. The ECS AMD690GM-M2 scores slightly lower probably due to the lower clk of 200.00.
