EPoX EP-AF550G Pro/G (NVIDIA 6100-430) mainboard review
Sandra XI
Benchmarks In this test, we measured the CLK used by the boards. Both boards are set to run in SPD mode of the modules which is rated CAS 5, 5-5-15, 2T. The ECS RS485-M-M and SIS 771 reference board runs on 200.00MHz on the dot. The EPoX EP-AT690 Pro runs at 200.7MHz whereas the ECS GeForce6100SM-M and the EP-AF550G Pro/G runs at 200.9MHz.
With that in mind, we take a look at the memory benchmark scores using Sandra XI. From the chart, it can be seen that the memory benchmarks used is almost the same as most of the integrated chipsets. The interesting result comes from two other ASRock boards which has better scores. Will that result in better overall standings. Lets read on.
