GA-G33M-DS2R is unlike other mATX board. It
comes with Robust Graphics Booster just like the discrete chipset
mainboards. You can turn on Fast, Turbo to speed up the graphics
perforamance
CPU Ratio is
adjustable for processors that supports it.
CPU Frequency range 100 ~ 700MHz
PCIe CLK can be set
from 100 ~ 150MHz
Another perforamnce
enhancement option is available to o/c the system.
