Performance of Gigabyte GV-NX86T256D Silent Pipe II (GeForce 8600GT)  - DOOM3 benchmark results
Bluetooth 17 Apr 2007
GF 8600GT
Benchmarks
DOOM 3
In DOOM3, we take take a look at various AA + AF combinations of the 8600GTS, 8600GT, 7900GT, X1950Pro and ATI X1950XTX.
Firstly, let's take a look at the 8600GTS card. With AA/AF set to application controlled in the NVIDIA control panel, we get results of 69.3 and 73.2 respectively for the ECS and Chaintech 8600GTS cards. This score is generally comparable to the ATI X1950Pro card in real games. Once AA/AF is applied, we see a drastic drop in performance to 15fps and 26 fps. that is lower than that of the X1950Pro and 7900GT.
The same can be said about the Gigabyte 8600GT graphics card. The results are lower than the 8600GTS cards and the difference is quite noticable. In fact, this game is probably not very playable at AA/AF combinations as it drops below the 25fps.
It would be fine if one choose to play DOOM3 using this card without AA/AF set. Alternatively, lowering the resolution could work with AA/AF set.
