Gigabyte P35-DQ6
(Intel P35) mainboard review - Introduction
Bluetooth 5 May 2007
of
AMD 690G boards
Introduction
Gigabyte
P35-DQ6 is Gigabyte's upcoming product based on the Intel P35/ICH9R chipset. It
supports the newer 1333FSB processors including all mutli core processors
including the 45nm processors. It alsos upport DDR2-1066*. It features Dual PCIe
graphics interface that supports CrossFire. Solid caps are used for for enhanced
stability and extended short circuit protection.
The board comes with SATA II and Quad eSATA2 interfaces. There is a Quad bios
solution for extended protection. 8 Ch audio codec ALC889A and DTS connect
features 106dB S/N ratio for wide range of home entertainment , gaming and
multimedia with best audio clarity. On top of all these, there is a GbE and 1394
support. The NB and SB are also passively cooled by Silent Heatpipe.
