Gigabyte P35C-DS3R DDR2/DDR3
(Intel P35) mainboard review - PCMark2005
Benchmarks PCmark2005
With PCMark05, we see that the scores are a bit of different due to the different memory controller of the 4 different chipsets. It is not difficult to see the difference between the P35-DQ6 and P35C-DS3R. We can more or less confirm that the low score previously recorded on P35-DQ6 is more of a BIOS issue. On the P35C-DS3R, the score is 7827, it is closer to what the 965P-DQ6 scored on QX6700. THe NV680i performed better due to the higher numbers on disk I/O.
