Gigabyte P35C-DS3R (Intel P35) mainboard review - BIOS Screen Shots
Bluetooth 15 May 2007
AMD 690G
BIOS 1
P35C-DS3R comes with Robust Graphics Booster too. You can set it to auto, fast or turbo to boost the 3D graphics performance
CPU Clk Ratio allows you to set the multiplier of your processor. ES should have multipliers unlocked for you to lower down as far as 6x.
CPU Host Frequency. This board allows a window of 100MHz- 700MHz.
PCIe Freq ranges from 100~150MHz
System memory multiplier lets you run your memory in sync or async to the cpu clk thereby maximising your memory bandwidth
