Gigabyte P35-DQ6 (Intel
P35) mainboard review - PCMark2005
Bluetooth 31 may 2007
Benchmarks PCmark2005
PCmark2005
tests a number of important items in today's computing world. File Compression,
Encryption, Decryption, Audio Conversion, Web Page
Rendering, WMV Video Compression, DivX Video Compression, Physics Calculation
and 3D, Graphics Memory etc.
With
PCMark05, we see that the scores are a bit of different due to the different
memory controller of the 4 different chipsets.
Comparing the P35T-DQ6 with the P35C-DS3R and
P35-DQ6, we noticed that the P35T-DQ6 scored 7724 vs 7827 (DDR2 - P35C-DS3R) and
7620 (DDR2 - P35DQ6). As both DDR2 and DDR3 platforms are running at 1066. The
major difference is the CAS latency. DDR3 are SPD at CAS 7,7-7-20 while DDR2
memory modules are run at CAS 5-7-7-24. That could explain why the DDR3 seems to
be running lower than a DDR2 equivalent.
