Memory Bandwidth test of
Kingston HyperX KHX1100D3LLK2/2G DDR3-1066 (2x1GB) @ OCWORKBENCH
of |
Benchmarks
As we can see, CPU-Z detects it as CAS 7-7-7-20. Memory benchmark. Buffered returns 5716/5716 MB/s which is what you would normally get from a DDR3-1066 memory module running on a E6300.
From the CPU-Z screen capture, we can see that the memory is running at a multiplier of 4x. that is CPU at 266MHz, RAM is at 4x 266= 1066MHz.
Further tests were done with a QX6700 processor. Will CAS 7 give you results similar to CAS 6 of the GEIL memory module ? We benchmarked them and the results can be seen on next page.
