Kingston Low Latency CAS 3
DDR2-800 (2x1GB) KHX6400D2ULK2/2G Review @ OCWORKBENCH
of |
Introduction
This pair of modules model KHX6400D2ULK2/2G is tested and proven to work under Low latency. It is rated at CAS 3 and can clk at 800MHz at CAS 3, 3-3-10 at 2.3 to 2.35v.
So will it improve the performance of the system with these CAS 3 modules? Let's check it out.
Specs
Kingston low latency DDR2 800MHz HyperX memory
module :
PC2-6400 800MHz
CL3-3-3-10 @ 2.3-2.35V
240-pin Unbuffered DDR Modules
Voltage: 2.3-2.35V
