BIOS Screen shots 2 of
J&W RS780UVD-AM2+ AMD 780G+SB700 mainboard
Bluetooth 29 Jan 2008
BIOS 2
QX9770.
| CPU multiplier can be upped to
x25. It is best used with Black edition AM2 CPUs like 5000+ or 6400+ |
CPU-NB HT Link speed. AM2
default is 5x. Phenom 9600 will run at X9 (1800MHz) |
| Dimm voltage can be set, up to
+0.35v, that gives you a maximum of 2.15v |
CPU voltage control allows you
to boost the CPU voltage. A Max of 1.45v can be applied |
| NB voltage can be upped to
0.24v. This is an important setting if you wish to increase the GPU CLK |
SB voltage can be upped by
+0.03v |
