ASRock 4Core1600P35-WIFI+
Intel P35/ICH9R chipset mainboard review - SiSoft
Sandra XII Benchmarks
The ASRock 4Core1600P35-WIFI+, Gigabyte GA-X48T-DQ6 and GA-P35T-DQ6 are put to the test using SiSoft Sandra XII. From the chart, we tested the Arithmetic and multimedia performance of the CPU. The CPU used is a QX9770 which clocks at 3.2GHz (400 x 8). One thing to note is that with P1.00 bios, the RAM timing is fixed at CAS 6, 7-7-20, setting the CAS latency to other settings result in no BOOT. Looks like it is a BIOS bug in p1.00
Comparing the two boards the Gigabyte GA-X48T-DQ6 and ASRock 4Core1600P35-WIFI+ both paired with a ECS 8800GT Graphics card, we noticed that the differences is very insignificant.
