| Review Conclusion
of
ASRock 4Core1600P35-WIFI+
Intel P35/ICH9R chipset mainboard review Conclusion
 ASRock surprised everyone with their entry into the mid range market with the release of the ASRock 4Core1600P35-WIFI+. As we have mentioned before, we have never seen such a high specification board from ASRock reviewing their products all these years. Based on the Intel P35 + ICH 9R chipsets. The board
supports all LGA 775 for Intel® CoreTM 2 Extreme / CoreTM 2 Quad / CoreTM 2 Duo
/ Pentium® Dual Core / Celeron®, supporting Penryn Quad Core Yorkfield and Dual
Core Wolfdale processors. The board also incorporates a all solid capacitor
design. In our o/c test, we used a E6300. Overclocking with DDR2 module seems to be easier than using DDR3. With our DDR2-800 module, we can set set option to run the module at DDR2-667 (min setting), this makes it difficult for us to overclock with this ratio of 266:333 (CPU:MEM). Using DDR3 modules, memory options available are only DDR3-800 or DDR3-1066, Running at DDR3-800 is the minimum setting we can choose. This results in a ratio of 266:400 and 266:533. Thus, it might be easier to lower the CAS Latency and pair the system with a high speed low CAS DDR3 module, perhaps a CAS 8 DDR3-1800. We also noticed that the memory CAS latency support seems to stop at CAS 6 with DDR3 module. Anything beyond, CAS 7,8,9 resulted in no POST at all. Looks like more work need to be done to solve these bios bugs. 1333MHz FSB CPUs probably gives better CPU:MEM ratios which can be used. I would assume that if we paired the board up with a 1333Mhz FSB CPU, CPU:MEM=1:1 can be chosen, in this case, when we o/c the 1333FSB CPU (333MHz effectively) to 500MHz, the memory will run at DDR2-1000, running the same CPU at 600MHz will only require the memory module to run at 600MHz (DDR3-1200) which is easily achievable. In this case, the memory module will not hinder the o/c process. The screen shot below shows a E6300 o/c to 420x6 in BIOS, with DDR3 set to 1.82v, the rest are set to AUTO. In OC tuner, the FSB is further raised to 450MHz. Notice that the memory module is running at CAS 5, 9-9-12,2T at DDR3-1344 (675x2).
 In conclusion, ASRock has impressed me with this new product. It is very complete and it is as good as the big brand ASUS or Gigabyte. If you want the best cost/performance Intel P35 board, ASRock 4Core1600P35-WIFI+ is definitely a good choice to consider.
| (C) Copyright 1998-2008 OCWorkbench.com
