Realtek RTL8111C GbE controller |
Before installing the processor, be it a FSB1066 or
FSB1600 with DDR2 or DDR3, please set the jumper properly. Please see manual
for instructions |
The jumper that needs to be shorted FSB1,2,3 if you intend
to use the FSB1600 or FSB 1066 processors. Please see manual for more
instructions. Picture of jumper and CLK GEN. |
The RTL8187L chip on the Wireless add on module which
comes with the package that you can either use it to login to a AP or make
your system an AP. |
