F.E.A.R benchmark of
ASROCK AOD790GX/128M AMD
790GX+SB750 mainboard
Benchmarks - F.E.A.R In the F.E.A.R Multiplayer DEMO benchmark, it is tested in MAX/High Setting for CPU/GPU. All 3 boards ASRock AOD790GX/128M, BIOSTAR TA790GX A2+ and Gigabyte GA-MA790GP-DS4H scored 26fps with UMA enabled. With Sideport enabled, both ASRock and Gigabyte gets a boost of 4 fps to 30 fps while Biostar runs at 28 fps. The noticeable difference is when it is overclocked at 1GHz, The ASRock scored 31 fps while the Gigabyte scored 33 fps. 2 fps slower than the DDR3 sideport version of 790GX. |
