Review Conclusion
of
ASROCK AOD790GX/128M AMD
790GX+SB750 mainboard Conclusion
If you are looking for a complete HTPC, gaming solution based on the AMD platform, the AMD 790GX/SB750 seems to have the best answers for these users. If you have already read our previous reviews on the 790GX/SB750, you already knew the feature set of the chipset. Pairing up with different sideport memory, and providing a complete video output solution makes one book outshine the other. Features-wise, the board is equipped with a 2 PCIe x16 slot which can work in a single PCIe x16 or Dual PCIe x8 in CrossFire mode. There are also 6 SATA II ports supporting raid 0,1,5,0+1 and it has eSATA support. In addition, there is 1394, GbE, HDA, USB. The board also comes with a 128M Sideport which helps boost the 3D performance of the iGP. As for CPU overclocking, the BIOS comes with a wide
range of options including memory timing, voltages, wide range of HTT etc. See gallery for more information.
You could also use the supplied ASRock OC tuner tool in the CDROM to overclock the
board. In addition, on the SB750 (SB) of the board is the
Embedded Controller for AMD OverDrive- Advanced Clock Calibration. With that,
we can run AMD Overdrive to overclock the CPU cores by adding a 4% increase in
all the 4 cores through this option below.
Although the board uses a DDR2-800 as Sideport, we can easily bumped it to run at DDR2-1066 by increasing the voltage. In fact, there is minute performance difference in using DDR2-800 vs DDR3-1333. With DDR2, it also keeps the price of the board competitive. In conclusion, ASRock has made history again with one of the all rounder boards. It did not cut corners and included features like 1394, eSATA. The ASRock OC tuner and Intelligent Energy Saver are also great help in completing the AMD solution.
