BIOS Screen shots 2 of
Introduction to ASROCK
AOD790GX/128M AMD 790GX+SB750 mainboard
Bluetooth 15 Sep 2008
BIOS 2
The screen shots are taken with board installed with a Phenom 9550.
For 790GX, you can set the
integrated video to use UMA only, Sideport only or UMA+Sideport. With
UMA+sideport, it gives you the best performance for IGP. |
Sideport memory clock can run
in various timings from 400 to 1066MHz |
When ACC is enabled, you get
to choose a percentage ranging from -12% to 12%. This is said to help in the
overclocking of the CPU. |
DRAM voltage can be upped to
2.7v |
mGPU voltage can be set up to
1.45v |
Sideport voltage can be set to
auto, normal or high |
With ASRock AOD790GX/128M you
can now save your user profile. There are 3 slots for your setup. |
