3Dmark05,
3Dmark06, 3DMark vantage benchmark of
ASRock G43Twins-FullHD Intel G43+ICH10 mainboard Benchmarks - 3Dmark2005/3DMark2006/3Dmark vantage In this test, the board is tested at default speed. In 3Dmark05, the score of ASRock G43Twins-Full HD is 1522 whereas the G45 is 1906. That is understandable as G45 should run faster and it is paired up with a better processor.
In 3Dmark06, the score narrows to 1160 vs 1180. This is an interesting result as we see that with a QX9770, you could only gain 20 more points against a lower CPU and chipset (E6550+G43). What would happen to some other applications? Let's continue to see.
The same tests are applied to 3Dmark Vantage in Performance mode. Unfortunately, the benchmark is unable to complete this test. Setting it to a lower mode doesn't help too.
