Under Smart Settings, you can choose to load Bios default,
Load performance default for a AHCI or IDE/SATA configuration or load a
power saving setup default. The performance defaults o/c the iGPU making the
board performs better in graphics. |
There are various overclocking modes. It can be set to
Auto, Manual, I.O.T or Optimized. If you want to fix the FSB to the 266,
just set Manual and enter 266 into the CPU Freq. |
DRAM Frequency sets the memory to run in ASync. In our
example, we used E6550 and have to set the jumpers so that we can run the
memory at DDR2-1066. In fact, the memory runs at a ratio that gives it
DDR2-1000. |
The amount of share memory. For 2GB DDR2 on board, 256M is
shared for use with the integrated GPU |
