Review :
Mainboard Layout of
ASRock K10N750SLI-WiFi NVIDIA nForce 750a mainboard (MCP72) mainboard Gallery The full ATX board comes with a 5 phase PWM. It comes with 3 PCI, 2 full length PCIe x16 (2 x8 or 1 x 16) and 1 PCIex1 slot on board. The board comes with Realtek GbE and Realtek ALC890B 7.1 ch audio. The single chipset runs hot during operation and is cooled passively. The board supports four 240-pin unbuffered non-ECC DDR II SDRAM DIMM sockets with up to 4GB per DIMM; 32GB of memory can be installed on board. For AM2 processors, DDR2-533/667/800 is supported. For Phenom AM2+, memory supported is DDR2-667/800/1066. It also support Asynchronous clocking mode between FSB and DIMM. On the left hand bottom corner, we can see the chipset attached with a passive heatsink. 6 SATA II ports with 1 being shared (Orange) for external SATA. The chipset also support a IDE port. At the centre, we can see the VIA chipset that controls the 1394. There is a peddle card provided which switches the green slot into a PCIe x16 or a PCIe x8 (for use with SLI with the blue slot).
At the rear panel are PS/2 keyboard connector. A coaxial, S/PDIF digital out. 1 eSATA, 6 USB, 1 GbE , 1 1394 and 7.1ch audio ports.
