ASRock K10N78hSLI-WiFi NVIDIA GeForce 8200 (MCP78) mainboard - Benchmarks SiSoft Sandra XII
Bluetooth 9 June 2008
Benchmarks
The board is tested with a Phenom 9550. The CPU clocks at 200MHz x11. The test is done using Sisoft Sandra XII. The first set of results is with an external 8500GT with hybrid SLI disabled. The second set of scores are with External 8500GT graphics card with hybrid SLI enabled. From what we see below, enabling hSLI will not affect the memory bandwidth at all.
* In the test, Chaintech 8500GT is downclocked to 450/900/400(core/Shader/mem) memory used is Corsair DDR2-1066 running at C5,7,7-24, 2T
Sandra XII ASRock K10N78hSLI-WIFI ASRock K10N78hSLI-WIFI (HSLI)
CPU CLK 200x11 200x11
Memory Bandwidth 5451/5449 5439/5430
Arithmetic - Dhrystone ALU 32515 32452
Arithmetic - Whetstone iSSE3 28070 28029
Multimedia - Int x8 iSSE3 82734 82640
Multimedia - Float x4 iSSE2 109012 108710
Drive Index 48 48
Random Access 7 7
