Review :
Mainboard Layout of ASRock K10N78hSLI-WiFi NVIDIA
GeForce 8200 (MCP78) mainboard Gallery The full ATX board comes with a 5 phase PWM. It comes with 3 PCI, 1 full length PCIe x16 (2 x8 or 1 x 16) and 2 PCIex1 slot on board. The board comes with Realtek GbE and Realtek ALC890B 7.1 ch audio. The board supports four 240-pin unbuffered non-ECC DDR II SDRAM DIMM sockets with up to 4GB per DIMM; 32GB of memory can be installed on board. For AM2 processors, DDR2-533/667/800 is supported. For Phenom AM2+, memory supported is DDR2-667/800/1066. It also support Asynchronous clocking mode between FSB and DIMM. On the left hand bottom corner, we can see the chipset attached with a passive heatsink. 6 SATA II ports with 1 being shared (Orange) for external SATA. The chipset also support a IDE port. The SATA ports support RAID 0, RAID 1, RAID 0+1, RAID 5, JBOD), NCQ, AHCI and Hot Plug functions. At the centre, we can see the VIA chipset that controls the 1394.
At the rear panel are PS/2 keyboard and mouse connectors. A coaxial, S/PDIF digital out. 1 eSATA, 6 USB, 1 GbE , 1 1394 and 7.1ch audio ports.
