ASRock
P43R1600Twins-WiFi Intel P43 chipset mainboard review - Introduction
Introduction
ASRock has been releasing so many high end boards lately. Today, we take a look
at a more mainstream product, the ASRock P43RTwins-WiFi based on Intel P43
chipset+ICH10R.
So, what is the difference between a P45 and P43 chipset. Basically,
the P45 supports Dual PCIe 2.0 x8 for CrossFire if you are not for
CrossFire, the P43 should sufficient as it only has a single PCIe 2.0 x16 slot.
The chipset supports all series of LGA 775 for Intel® Core™ 2 Extreme / Core™ 2
Quad / Core™ 2 Duo / Pentium® Dual Core / Celeron®, supporting Penryn Quad Core
Yorkfield and Dual Core Wolfdale
FSB1600/1333/1066/800MHz CPUs. This board also supports a dual memory
architecture - Dual Channel DDR3 1333/1066 (2 x DIMM slots) with max.
capacity up to 4GB and Dual Channel DDR2 1066/800/667 (4 x DIMM slots) with max.
capacity up to 8GB
THe board supports a PCIE Gigabit LAN 10/100/1000 Mb/s and 2 x IEEE1394 ports
(one port on back panel, one header on board). Audio is a 7.1 CH Windows® Vista™
Premium Level HD Audio with Content Protection, supports DAC with 110dB dynamic
range (ALC890 Audio Codec), DTS (Digital Theater Systems).
The on board WiFi/E header connects to
ASRock WiFi-802.11g Module
for WiFI/AP, making this board part of a wireless LAN network.
For overclockers, the board's BIOS also support I.O.T, allowing you to overclock with ease. There
are also a large amt. of voltage options and large range of Frequencies (200 ~
800) etc for you to overclock. If it is not enough, you can use the ASRock OC
tuner to achieve a higher overclock within Windows.
