ASRock
P45R2000-WiFi Intel P45 chipset mainboard review - BIOS Screen shots
Bluetooth 21 Jul 2008
BIOS 1
QX9770.
With QX9770 and a pair of
Kingston DDR3-1800, we ran the board in DDR3-1333 mode. DDR3-1600 is
selectable but the board couldn't boot as it is not supported. (but option
available in BIOS). |
CPU Freq range can be set from
100 ~ 800MHz. PCIe can be set from 100 ~ 150MHz. Ratio (Multiplier) can be
enabled when Intel Speed Step is disabled. |
DRAM settings can be adjusted.
Memory DRAM frequency for my QX9770 allowed are DDR3-800, 1066, 1333. 1600
is there but the system won't POST. |
CPU voltage adjustments can be
set up to 1.60v |
