ASRock
Penryn1600SLIX3-WIFI NVIDIA nForce 680i chipset mainboard review - Introduction
Introduction
Last month, we reviewed the
Penryn1600SLI-110dB based on the nForce 650i chipset. ASRock delivers yet
another board based on the NVIDIA Intel series. This time round, it uses the
NForce 680i chipset. This new board model Penryn1600SLIX3-WIFI is based on the the NF680i + NF570i chipset.
If you remember, most of the 680i were NVIDIA home brewed boards and there
weren't able to anticipate support for the 1600FSB Processors at that time.
ASRock is able to deliver a new breathe of life for the aging chipset with
support for the
Intel QX9770 Core 2
Extreme Quad Core processor running 1600FSB. On top of that, it also
supports 3 Way SLI.
On top of all these, the board comes with a free Bundle: 802.11g WiFi module.
This allows you to transform your board into a AP or run it as a client for
wireless internet connection. For movie buffs, the on board ALC890 audio codec
with DTS support. The ALC890 audio codec supports signal to noise ratio of
110dB, and the S/N rate means the higher the ratio, the less obtrusive the
background noise is. And what’s best is that ASRock Penryn1600SLIX3-WiFi
supports DTS, which makes the sound from game or software become a 7.1 channel
audio output through the surround speakers, and it also can simulate the
2-channel audio file, (MP3, WMA..) to a 7.1 channel audio output through the
surround speakers.
Better capacitor is also one of the most important criteria to users. ASRock
Penryn1600SLIX3-WiFi is designed with all solid capacitors, which enhances the
durability, over-clocking, reliability and safety of it. You can also install
the ASRock OC tuner to oc your CPU within Windows.
Wth solid caps and heatpipe design, the board will cool better and last longer.
Specs
* LGA 775 for Intel® Core™ 2 Extreme / Core™ 2 Quad / Core™ 2 Duo /
Pentium® Dual Core / Celeron®, supporting Penryn Quad Core Yorkfield and Dual
Core Wolfdale processors
3 way SLI bridge and 2 way SLI bridge are provided. The WIFI/AP card and antenna
is also bundled in the package.
