| Over at this screen, the main
settings for CPU Frequency and PCIe Frequency can be set. CPU Frequency
ranges from 100 ~ 800MHz while PCIe Freq ranges from 100~150MHz. Overclock
mode can be ASync, Sync or Auto. Multiplier can be set too (supported CPUs
like ES). |
DRAM Frequency can be set to
operate in ASync memory settings of 400,533 or 800MHz. Options will be
different if you use DDR2 module. Note: If you use DDR2-1066, you need to
set the jumpers, please refer to manual for settings. Ram timings can be set
on this page too. |
