Review : ASUS Eee PC
900 based Intel Mobile Celeron 900MHz with 8.9" Screen
Integrated Devices on the Eee PC 900
The XP Version of the EeePC 900 comes with some softwares
pre-installed. They are Acrobat Reader 8, Skype, StarSuite 8 etc. Below is a screen shot of the system information. The CPU used on this
machine is a Intel Celeron Mobile processor clocking at 900MHz. The unit is
installed with 1 GB of DDR II of memory. We have checked with ASUS if users can
upgrade that to 2GB. Here is what they say Users can upgrade the Eee PC 900 to 2GB RAM but we do not recommend to do
so. Reason being that the Eee PC 900 is a gadget which we would like users to
use as what it is provided. If they really upgrade to 2GB Ram, warranty will not
be void but they would need to keep the original 1GB RAM. However, our
technicians do not provide service on upgrading of the RAM for the Eee PC 900. The device manager gives you a bird's eye view of the devices installed. We
can see that the SSD devices. The device also uses an older 915GM chipset
instead of a 945GM. The Wireless network and Fast Ethernet port uses
Artheros chipsets.
