ASUS
P5Q-E Intel P45 mainboard review
- BIOS Screen shots
Bluetooth 7 Jun 2008
BIOS 2
QX9770.
Memory level can be set to run
in ASync mode to the CPU CLK. Here are three options available when the
board is installed with a QX9770.
FSB range 100 ~ 800MHz. |
CPU Vcore can be set from 0.85
to a max of 2.10v |
DRAM voltage can be set from
1.0v to 3.0v |
NB voltage can be set from
1.10v to 2.20v
SB voltage can be set from 1.10v to 1.40v |
CPU ratio can be set |
CPU voltage can be raised to a
maximum of 2.40v |
