3Dmark05 and
3Dmark06 benchmarks of ASUS Striker II Extreme nForce 790i Ultra SLI mainboard
review Benchmarks - 3Dmark2005/3DMark2006
Paired with a Vvikoo 9600GT Turbo on board using QX9770, the
mainboard is tested for it's performance in 3DMark05 and 3DMark06. The same card is paired with a ECS 9600GT with Accelero S2 we
reviewed before to test for SLI performance. As we can see form the chart below, the Gigabyte P35T-DQ6
performs slightly better with the same graphics card, scoring 19009 while the
ASUS Striker II Extreme only attained a score of 18449. As both nForce 650i, nForce 680i and nForce 790i all support
SLI configurations, we put them to the test using the same Forceware driver
174.16. To our surprise, the ASUS Striker II Extreme only scored 19425 while
both ASRock boards scored 20351 and 20434. Could it be that the overclocked
ASRock boards also overclocked the PCIe bus or is it a BIOS issue?
In 3Dmark06, the ASUS Striker II Extreme does
better with a score of 11935, 5 points lower than the ASRock
Penryn1600SLIX3-WIFI. In SLI
mode, it scored 15598, and again, we see that both ASRock boards using the older
chipset surpassing the performance of the brand new nForce 790i SLI chipset.
This is getting weird. Will this trend continue in the other tests ? Let's see.
