| Need more voltage for your
PLL, it can be raised to 3.0v |
CPU VTT can be raised to 2.46v |
| Memory voltage can be set to
3.10v |
MB Core voltage can be set up
to 2.20v |
| SB Core Voltage can be
increased up to 1.85v |
For better o/c results, you
can switch off the other 3 cores by disabling them in the BIOS |
| Here is the interface of the
Extreme Tweaker of the BIOS. |
