Review : Introduction
to DFI LP JR 790GX-M2RS AMD 790GX+SB750 Mainboard
Bluetooth Bluetooth 24 Dec 2008
Introduction
It is been some time since we last reviewed a AMD 790GX
mainboard. Today, we take a look at one of the most flexible mATX solutions from
DFI.
This board features the AMD 790GX+SB750. It comes with DX10
integrated ATI Radeon HD 3300 graphics core. Without an external graphics card,
you are ready to get it power up with the Onboard graphics interface - HDMI port
for both digital audio and video HD display - DVI-I port for digital LCD
display.
As we all know, most AMD 790GX boards out there are designed
to accommodate two full length slots to support CrossFire. The DFI lanparty JR
790GX M2RS is probably the first mATX board to feature a 2 full length
PCIe slot for CrossFire function. Not only that, it also supports Hybrid
CrossFire and other features like DDR2-1066, Marvell 88E8056 PCIE Gigabit LAN
controllers, Realtek ALC885 8-channel HD Audio Codec7.1 ch audio etc.
This board supports the AMD® AM2+ processors: Phenom FX /
Phenom / Athlon / Sempron AMD® AM2 processors: Athlon series / Sempron with
HyperTransport 3.0 (5200MT/s for AM2+) HyperTransport 1.0 (2000/1600MT/s for
AM2). The AMD OverDrive provides tuning options using the new “Advanced Clock
Calibration” overclocking feature is also supported via SB750. The new BIOS
available also supports the new 45nm Deneb core AM2+ processors e.g. Phenom II
X4
The board comes with 4 x 240-pin DDR2 DIMM sockets and
supports DDR2 667/800/1066 MHz DIMMs, dual channel (128-bit wide) memory
interface of up to 8GB unbuffered non-ECC x8 and x16 DIMMs.
Other features included are CMOS Reloaded, CPU/DRAM
overclocking, CPU/DRAM/Chipset, Overvoltage, 8Mbit SPI flash memory and ABS-
Auto boost system.
Specs
CPU
# AMD® AM2+ processors: Phenom FX / Phenom / Athlon / Sempron AMD® AM2
# HyperTransport 3.0 (5200MT/s for AM2+) HyperTransport 1.0 (2000/1600MT/s for
AM2)
# AMD OverDrive provides tuning options using the new “Advanced Clock
Calibration” overclocking feature.
# Socket 940 AM2+ 65nm
Chipset
# AMD chipset - Northbridge: AMD 790GX - Southbridge: AMD SB750
System Memory
# Four 240-pin DDR2 DIMM sockets
# Supports DDR2 667/800/1066 MHz DIMMs
# Supports dual channel (128-bit wide) memory interface
# Supports up to 8GB system memory
# Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots
# 2 PCI Express (Gen 2) x16 slots - Hybrid CrossFireX - combination of the
integrated graphics and a discrete graphics card in a PCIE slot (8-lane port). -
Two graphics cards support CrossFireX; each operating at x8 (8-lane ports)
bandwidth
# 1 PCI Express x1 slot
# 1 PCI slot
BIOS
# Award BIOS
# CMOS Reloaded
# CPU/DRAM overclocking
# CPU/DRAM/Chipset overvoltage
# 8Mbit SPI flash memory
Graphics
# Integrated ATI Radeon HD 3300 graphics core
# Onboard graphics interface - HDMI port for both digital audio and video HD
display - DVI-I port for digital LCD display
# Microsoft® DirectX 10
# Hybrid CrossFireX technology combines the onboard GPU and a discrete PCIE
graphics card
# Onboard Performance cache for added performance
Audio
# Realtek ALC885 8-channel HD Audio Codec
# High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB
LAN
# Marvell 88E8056 PCIE Gigabit LAN controllers
# Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab
(1000BASE-T) standards
Serial ATA with RAID
# Supports up to 6 SATA devices
# SATA speed up to 3Gb/s
# RAID 0, RAID 1 and RAID 0+1
IDE
# One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
Rear Panel I/O
# 1 mini-DIN-6 PS/2 mouse port
# 1 mini-DIN-6 PS/2 keyboard port
# 1 HDMI-out port
# 1 coaxial RCA S/PDIF-out port
# 1 optical S/PDIF-out port
# 1 DVI-I port
# 4 USB 2.0/1.1 ports
# 1 RJ45 LAN port
# Center/subwoofer, rear R/L and side R/L jacks
# Line-in, line-out (front R/L) and mic-in jacks
Internal I/O
# 4 connectors for 8 additional external USB 2.0 ports
# 1 connector for an external COM port
# 1 front audio connector
# 1 CD-in connector
# 1 IrDA connector
# 1 CIR connector
# 6 Serial ATA connectors
# 1 40-pin IDE connector
# 1 floppy connector
# 1 24-pin ATX power connector
# 1 8-pin 12V power connector
# 1 4-pin 5V/12V power connector (FDD type)
# 1 front panel connector
# 6 fan connectors
# EZ touch switches (power switch and reset switch)
Power Management
# ACPI and OS Directed Power Management
# ACPI STR (Suspend to RAM) function
# Wake-On-PS/2 Keyboard/Mouse
# Wake-On-USB Keyboard/Mouse
# Wake-On-Ring
# Wake-On-LAN
# RTC timer to power-on the system
# AC power failure recovery
Hardware Monitor
# Monitors CPU/system/chipset temperature
# Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
# Monitors the speed of the cooling fans
# CPU Overheat Protection function monitors CPU temperature during system
boot-up
PCB
# microATX form factor
# 24.5cm (9.64") x 24.5cm (9.64")
