Benchmarks -
Lost Planet
In the game benchmark Lost Planet, the benchmark is done at 1280x720, other
settings are set as default.On the ECS A780GM-A Ultra, it scored 9/7 and
14/10 for this test. Again, we can see that after o/c it to 1GHz, the ECS
A780GM-A Ultra can actually match a 790GX board running at 700MHz and with
Sideport enabled. Biostar scored 13/9 Gigabyte scored 13/10.
With UMA only, the ASRock board scored better
than the two other boards. It scores 13/10 for Cave/Snow. The two other boards
scored 12/9.
With Sideport enabled, the score is upped to 14/11, Biostar 13/9 and Gigabyte
13/10. With the board Overclocked to 1GHz, it scored 16/12 vs Biostar 15/11 and
Gigabyte 16/12.
In this test, the difference is all within 1 -2 fps.
