BIOS Screen shots 1 of
Introduction to
ECS A780GM-A Ultra
AMD 780G+SB750 Mainboard Review
HT Frequency can be set to 200,400,600,800,1000 or 1800MHz |
As 780G chipset does not support sideport memory. It only allows you to set the share memory size. In addition, ECS A780GM-A Ultra allows you to o/c the iGPU Clk from default of 500MHz to 2000MHz(2GHz) |
We can run the memory at DDR2-1066 by setting it to 533MHz over here for memclk value. |
Over here, Ram timing adjustments can be set accordingly. |
With SB750 south bridge, this board supports the AODACC overclocking. To enable it, you have to set the advance clock calibration to All cores, 4%. |
Recommended setting is +4% |
