3Dmark05,
3Dmark06, 3DMark vantage benchmark of
ECS G45T-M2 Inlel G45+ICH10 mainboard Benchmarks - 3Dmark2005/3DMark2006/3Dmark vantage In this test, the board is tested at default speed. In 3Dmark05, the ECS G45T-M2 scored 1524. This is quite shocking as the ASRock G43Twins-FullHD scored almost identical. The Gigabyte scored better because it uses a QX9770 processor.
In 3Dmark06, the ECS G45T-M2 scored 1118 whereas the ASRock G43 does better. We are starting to suspect the ASRock G43 is not running at default clks.
The same tests are applied to 3Dmark Vantage in Performance mode. Unfortunately, the benchmark is unable to complete this test. Setting it to a lower mode doesn't help too on all G43 and G45 boards.
