3Dmark05, 3DMark06 and 3Dmark Vantage benchmarks of ECS P45T-A mainboard
Bluetooth 15 Jul 2008
Paired with two pieces of AMD Radeon HD 4850 running in Single and CrossFire mode with Cat 8.6+patch. we tested out the board in a single and Dual 8x cross fire configuration.
In a single card configuration, it scored 18187, it seems to perform slower than the rest of the P45 boards. In CF mode, the results went up to 21083 which still falls behind the two other boards tested in CF mode.
In 3Dmark06, single card performance is 13032. Although it is slightly faster than the Gigabyte GA-EP45 Extreme, it still falls short of a few percentage points behind the ASRock P43R1600Twins-Wifi board. in CF mode, the score is 17390 which gives it a mid range score between the two other boards tested in CF.
In 3DMark vantage, the score for the Performance is 7098 (single card) and 11655 (crossfire). The score is better than the Gigabyte but lost to the ASRock. in CF mode, it's 11655 is better than the Gigabyte but still falls short of a 50 points to the ASRock X48. Will 3Dmark results gives you an indication on how it will perform in real game demos. Read on to find out.
