The screen shots are taken with board installed with a QX9770.
CPU Termination voltage can be
upped to 1.50v |
CPU Ref voltage can be upped
to 1.020v |
VGA core is selectable from
200 to 2000MHz. The default is 700MHz (but on F1 bios is 500MHz). |
The Memory clock can be set
for the integrated GPU. At 5.33x, it will run at 533MHz. |
PAVP mode can be set to Lite
mode or Paranoid PAVP. This allocates more memory to the integrated graphics |
Available options range from
32MB to 256MB |
The board comes with TPM. This
is where you set up the security chip |
