DOOM3 benchmark of Gigabyte GA-MA790GP-DS4H AMD 790GX+SB750 mainboard
Bluetooth 5 Aug 2008
Benchmarks - DOOM3
With DOOM3, this benchmark is run at 1600x1200 Hi Quality. With UMA only, it scored 19.4 fps which is hardly playable at this resolution. It was then tested with SP enabled, the score improved by 4 fps to 23.3fps, a 20% jump in performance.
With the GPU o/c to 1GHz and sideport enabled, the score shot up to 26.2 fps, that is a 35% improvement over UMA only.
