The screen shots are taken with board installed with a Phenom 9550.
| Sideport memory voltage can be
adjusted by up to +0.3v for more stability when overclocking |
NB voltage is necessary to be
upped if you intend to overclcok the GPU. It can be set up to +0.3v |
| DDR2 voltage can be upped to
+0.55v of default |
CPU NB VID Control can be
upped to +0.60v |
| CPU voltage can be upped by
+0.6v |
You can disable the UMA,
enable it or set to operate it in UMA+Sideport for better performance |
