Gigabyte GA-X48T-DQ6
Intel X48 chipset mainboard review - BIOS Screen shots
Bluetooth 31 Dec 2007
BIOS 2 (Updated with BIOS F3c)
QX9770.
Robust Graphics Booster is set
to AUTO for the test. It can be turned to Fast and Turbo for better
performance |
As it is a ES of QX9770, the
multiplier can be selected from a range of 6x to 16x. |
CPU Freq has a wide range from
100 to 700MHz |
PCIe freq can be fix at 100MHz
or up to 150MHz can be chosen. |
C.I.A.2 (intelligent
accelerator 2) is another mechanism which you can just select to overclock
the system. |
There is another option which
is known as performance enhance which again helps to boost performance. |
