Call Of Juarez Benchmarks Results of Gigabyte GV-NX98X1GHI-B NVIDIA 9800 GX2 Graphics card
Bluetooth 27 Mar 2008
Benchmarks
Call of Juarez (DX10)
We tested the DEMO of Calls of Juarez in VISTA. Take note that COJ applied a 4xAF by default. The test is done at 1600x1200.
At defaults, we see a score of 38.5 fps. At 4GHz, it shot up to 43.7fps. With GPU oc to 720MHz, the frame rate increase further to 47.6 fps. That is 30% improvement.
When we applied 16xAA/16xAF to the card at defaults, the results dropped to 36.5 fps. This is probably due to the application was already default to applying 4xAF in the application.
