Conclusion of Gigabyte GV-NX98X1GHI-B NVIDIA 9800 GX2 Graphics card
Bluetooth 27 Mar 2008
NVIDIA reference design with a Gigabyte sticker. Well that is for the GV-NX98X1GHI-B graphics card. Although it comes in a reference design, the performance is really one of it's kind. So far, we have not seen any card that performs that well in performance levels. Our previous tests of 2 x 8800GT overcooked won't probably match the performance levels of the GV-NX98X1GHI-B.
As usual, NVIDIA's coolers isn't' comparable  to those of Zalman or Accelero. We  used the ATitool's 3D artifact detection software, we left the card to run. Using ntune, we read off the temperature readings. At normal room temperature of around 30 Degrees, the GPU temp maintains at 67 degrees Celsius. After 10 mins of running the catalyst artifact scanner, the GPU temperature rises steadily to about 75 degrees Celsius. At the end of the 15 mins, the scores are GPU1:75 deg Celsius and GPU2:80 deg Celsius
As it uses 2 G92 GPUs, the card does not support DX10.1 and SM 4.1. The card is also different from ATi cards which comes with an embedded audio controller for HDMI out. If you intend to use the card as a HTPC video processor, you would need to channel the audio from your audio card to the audio pins located on the card.
In conclusion, the card is superb in 3D performance. The card also display amazing overclocking performance. On top of that, you could use it to playback / decode your HD programmes with low CPU utilisation.
Price
  • Quad SLI support
  • Audio cable provided
  • Two slot design
  • No DX10.1 / No SM4.1
  • No Game bundle
 Category Score
 Performance 10 / 10
 Features 10 / 10
 Ease Of Installation 10 / 10
 Documentation 8 / 10
 Packaging & Bundle 7 / 10
Cost Performance 7 / 10
 Overall Rating : 8.6 / 10
