Review Introduction to Gigabyte
GV-NX98X1GHI-B NVIDIA 9800 GX2 Graphics card
Bluetooth 27 Mar 2008
Introduction
Graphics card performance is ever
changing. Although NVIDIA still maintains the lead over competitor AMD in it's
single core card, they have not stopped making Dual GPU design for the non SLI
capable boards out there.
With two on-board G92 GPUs, a GeForce® 9800 GX2-based
graphics solution is bar-none the fastest graphics card available, and when
paired with a 7 Series NVIDIA nForce® motherboard, creates the latest in a line
of powerful NVIDIA gaming platforms. Be blown away by scorching frame rates,
true-to-life extreme HD gaming, and picture-perfect Blu-ray and HD DVD movies.
The dual-GPU engine has 256 screaming fast stream processors and a 1GB
frame buffer, allowing it to perform 30 to 50% faster across games than the
previous performance leading GeForce 8800 Ultra GPU.
Extreme HD game play, unsurpassed movie picture quality, and elegant design are
at your fingertips with the GeForce 9800 GX2-based graphics card. Now you can be
right in the middle of the action – whether you’re fragging the enemy or
watching an HD movie, your experience will be ultra-realistic.
Combine a pair of these multi GPU graphics cards with an nForce® 790i
motherboard for Quad NVIDIA SLI® technology and get the world’s fastest gaming
PC. Plus, an ESA-enabled control panel provides a state-of-the-art interface and
HybridPower™ technology gives you optimal power savings.
Gigabyte's GV-NX98X1GHI-B is such a card. It comes with 1 GB
GDDR3 and supports the PCIe 2.0 standard. It has 256 stream processors and
clocks at 600/1500/1000 (Core/Shader/Memory). The memory interface is 512 bits.
Gigabyte GV-NX98X1GHI-B is based on the
reference design. To date, it is the fastest graphics card made
available.
