3DMark06 and
3Dmark Vantage benchmarks of ASRock A780GMH/128M
AMD 780G+SB710 Mainboard Benchmarks - 3Dmark2006/3DMark Vantage
In this test, we paired up the board with a ASUS HD EAH4870X2
graphics card with the provided drivers in CDROM. The first test is running it
in tri core (default) and the second round is with the AOD ACC turned on, which
enabled the hidden 4th core. Below are the results : We see an increase of 5.6% in the 3DMark06 score. It
increases from 14431 to 15246. In 3DMark Vantage, the difference is around a 1000 points.
With X3 710 default it scored 10714, with the hidden 4th core enabled, it
increase to 11734. That is a 9.5% increase.
