BIOS Screen shots 2 of ASRock M3A790GXH/128M AMD 790GX+SB750 Mainboard
Bluetooth 18 May 2008
BIOS 2
The screen shots are taken with board installed with a AM3 X3 710 processor + ASUS Radeon HD 4870X2 EN TOP
The memory clk running in async to the CPU CLK Memory timings available for adjustments
If you use the integrated graphics, you can choose to use UMA, SIDEPORT or UMA+SIDEPORT to boost the iGPU performance The onboard GPU can also be overclcoked from it's default of 700MHz to 1GHz.
HT Bus Speed is selectable from 200MHz to 2GHz. You can lower this to ensure a better overclock.
